MS 365 Integration extension number sync
mikeodo
Titanium Partner
Sync the extension number directly from a field in Office 365
@mikeodo and where this field should be?
Unlike in a local AD, MS365 is no field for this anymore which should be used for this purpose.
I know, but could the administrator be free to choose which field to use in front of it?
The office is for sure out as this is required for our MS Direct Routing Integration.
And may customers still use req. the fax number. Therefore it is not a good solution that would be
usable for all.
KylieWilderman
