MS Teams sync in alpha u5 works only one way
bitn2
3CX MVP
Platinum Partner
Did somebody tested this already? We tried to test this on our pbx but the sync is only going from teams to 3cx and not in the other direction. Did we miss something? Also if we delete the sync for busy idle, this will be ignored .1734692019562.png
Can you re-Authorise again and try again.
We will try and give feedback.
Another thing we dont understand.. the url to authorize is different to the o365 url. We need to put both urls into the app
https://company.3cx.de/oauth2office2
and for the Teamssync
https://company.3cx.de/oauth2presence
Is this expected?
Yes both endpoints need to be configured as redirect URLs in the MS app
But you don't need to actually do it manually yourself.
Configuring M365 from 3CX will create/configure the app properly for you with both endpoints
This should work out of the box
Ok, we had o365 configured before. Thats why its not done automatically i think. Thx.
We set up the Microsoft 365 integration again, now it works perfectly. Thank you for the support.
Best regards
Finatra.us
