My Phone is not ringing
targettravelsqatar
New User
I have installed the 3CX in my android device and it giving notification for the ring but its not making the sound, I installed the 3CX in my another android devise and its working well, Could you please advise me why the device is not ringing..? The same device was worked well two days ago, Please help...!
What device? What Android version?
Have you tried enabling "Telecom API" in the app settings?
Hi, Its IQOO7 device from VIVO, How can I enabling "Telecom API" in the app settings?
Go in the 3CX app settings and check if there's a checkbox for Telecom API. If there is, try enabling it.
Reactions: targettravelsqatar
Could you please see the attachment and advice what has to be enabled...? I tried many ways
Hi @targettravelsqatar, thanks for the feedback.
From image seems the Telecome Api [Car/Bluetooth support (Telecom API)] is enabled.
Please disabled and retry.
If the issue not resolved, please send me in PM the verbose log report, after you enabled the buffer log size to the maximum.
  1. Enable Verbose Logs: “Android App Settings (top left hamburger menu) > Settings > Advanced > Troubleshooting > Verbose Logging”.
  2. Reproduce issue and “Generate Log Report”: Android App Settings (top left hamburger menu) > Settings > Advanced > Troubleshooting > Send Log Report.
Hi Dear, How can i get your email address to send this..?
Reactions: GiannosI_3CX
You can send it to your email, upload it to ftp server (You can use the wetransfer.com if ftp is not available) and provide me the link in PM please.
I have only basic knowledge in IT :(, If you can provide the email address would be better, OR you can advise me how to provide you the link
Please follow the steps below :
  1. Send the log report at your email
  2. Download the attachment when the email received (Filename : ACRA-report.stacktrace)
  3. Navigate to https://wetransfer.com/ and click on "I just want..."
  4. Upload the file there
  5. Provide me the generated link in PM
You can upload file here if this what are you seeing.
@targettravelsqatar I have download it. please delete your message. Log files must be send via private messaging and not in public threads.
Finatra.us
