nginx CVE-2026-123007
thegrs
I just noticed that there is a new High Severity vulnerability reported in the HTTP/2 implementation within nginx from version 1.9.5 all the way up to 1.30.6. I just checked my copy of 3CX version 20 update 10 and it is running nginx 1.30.6 with HTTP/2 enabled, so it is vulnerable.
From what I have been reading online, I can disable HTTP/2 within the nginx configuration file to protect the server for now. What would the implications be for 3CX with HTTP/2 disabled? How long before there is a patch from 3CX that includes the patched nginx 1.30.7? Any other suggestions to protect the 3CX installation?
Self Hosted
3CX Version 20 Update 10 (Build 1785 Release - AI 1.6.91)
Windows Server 2019
Have you learned anything more?
For the reported CVE's nginx has released an update however this is not yet released from Debian, we are currently checking also on our side and get back with an update as soon as possible.
I did some digging, and debian has not released a fixed version for Debian 12 Bookworm yet as of 2026-11-19 13:00UTC https://security-tracker.debian.org/tracker/CVE-2026-123007
However, the nginx binary is installed via the 3cxpbx package, not via the debian-maintained nginx package.
Should we mitigate by disabling HTTP/2 and would this disrupt 3CX functionality (WebApp/BLF/Provisioning)?
We were called yesterday by our EASM team and told to mitigate by blocking all traffic to the 3CX system until we get a patch. I complied and had our SOC do an analysis on the system, and we had not been exploited yet. 3CX as a company should be sending out warnings for customers to follow suit imo.
Not conclusive proof that it will not break anything, but I disabled http2 on a few U10 upgrades I did last night and couldnt see anything that didnt work. I also blocked SCTP whilst I was there
Noticed new Debian Security updates in 3cx this morning.
It would be nice to see some communication from 3CX on this matter.
We have disabled HTTP/2 everywhere and are waiting for a patch from 3CX.
If any 3CX developer is listening it's worth mentioning that with the default nginx.conf file the following warnings are logged to "C:\Program Files\3CX Phone System\Bin\nginx\logs\error.log":
2026/11/17 10:52:24 [warn] 8944#13740: the "listen ... http2" directive is deprecated, use the "http2" directive instead in C:\Program Files\3CX Phone System\Bin\nginx/conf/nginx.conf:48
2026/11/17 10:52:24 [warn] 8944#13740: the "listen ... http2" directive is deprecated, use the "http2" directive instead in C:\Program Files\3CX Phone System\Bin\nginx/conf/nginx.conf:49
Reactions: FM Telecom B.V.
We have spent some time this morning disabling http2 in the nginx config for customers we host, as well as on-prem instances we support. I have not heard reports of this causing any issues for web app users. I'm sure 3CX probably does not recommend that, though, so do it at your own risk.
We are working on the update.....
Thanks Nick, much appeciated! We will stay loyal and know you got this!!
Reactions: N_G
Thanks 3CX team for this quick fix, I think a lot of vendors can learn from this! :cool:
Reactions: MyForumUsername
youwillbrun
