Solved No Audio While Calling
ahsan041
Dear Experts,
i have configure the 3CX V16 on Windows Server 2012 R2 Cloud Machine and configured the 3CX App and it's working fine we are able to make calls on extensions outside of the network but there no audio between callers i configured it on static ip address and using it outside of the office not internally could you please help me in this regards and provide the solution so i can test it this software in better way and purchase it after testing.
all ports were opened as it's on AWS cloud i didn't restrict any ports on that specific server.
but some how i managed it make some rules and other things and it's working now and able to communicate on public network thanks alot for your help as well.
You need to make always port forwarding because networks are not exactly like home networks..
So it is not an android issue - it would have happened using any device..
Happy you solved your issues..
for the record and all the users using aws.. an aws network is different than some other network and this is what makes aws so cool
Between your device and 3CX installed on aws you have vpc - Amazon virtual private cloud which isolates resources and networks.
Then you have another layer called AWS direct connect which links your local network to aws resources and these 2 are super related because they are the link to the fiber networks and gigabit links they have. This is like you have a mega firewall in location a, and all the other virtual aws servers in location b. You do not see this as an aws customer and you think they are the same little server or machine, but it is nothing like this. This is large scale networking implemented beautifully by amazon..
So you had to make changes to the vpc section. otherwise there is no chance ingress will work. Egress from machine will be ok because its "inside out" and inside is trusted as traffic originates from INSIDE AWS.. But you, your phone, are outside and therefore untrusted. So you need to tell the vpc on aws to allow stuff.
RJenkinsROCK
