Office 365 integration - AADSTS50011
Test Teknik
Forum User
I have a 3CX system installed on Azure WM.
When I want to integrate with Office 365
"For Sign In to work please add this URL http://10.0.0.4:5000/oauth2office2 to the list of Redirect URLs in your Microsoft 365 App"
But Azure says it should start with HTTPS.
After all
"AADSTS50011: The reply URL specified in the request does not match the reply URLs configured for the application: 'df28dcce-80b1-462e-b058-1adc61696d4b'."
I get an error.
What am I missing? How can I fix?
Thanks in advance for your answers :)
Hello @Test Teknik,
You need to access your Management Console with the Public FQDN. You will need also a valid certificate for the communication with Microsoft Azure to be successful.
Hello Constantinos,
Below is the info I got for the FQDN in the management console.
Should I use the Azure management console to open the FQDN or do I have to do something from the 3CX management console?
<?xml version="1.0" encoding="utf-8"?>
<template>
<from_display_name/>
<subject>DNS resolution/ Network failure - %%SIPDOMAIN%%</subject>
<body>
Registration at %%PRODUCTION%% has failed.
Destination (%%DESTINATION%%) is not reachable, DNS error resolving FQDN, or service is not available.
</body>
</template>
Hello @Constantinos,
Thank you very much for your help.
After your actions, when Azure makes user, user type "member", contact synchronization is started.
Actually the user is supposed to make this section "member" in the "administrator" cell, not "member".
