Solved One way audio TEAMS to 3CX
gio.ruga
Hi All,
I setup the direct routing for Teams following the best practices, but when I call an external number or a 3cx extension, I can hear the receiver but he cannot hear me.
The 3cx is behind a firewall and I setup all the rules needed.
Can you help me?
thanks
Giorgio
Hi Giorgio,
First pleace run the Firewall Checker and make sure all tests pass. This can be done from the 3CX Dashboard --> Firewall.
Even if it already reports green and you have run it in the past, please repeat it now.
Also one more question, you you register a 3CX Extension using the 3CX app, and call the same external number, is there still one-way audio?
Also does the same happen when you dial from a 3CX Extension to another 3CX Extension?
Last, you say one-way audio. Which direction has the problem. When you are calling your Teams client, the external caller can hear you, but you can't hear them?
Hi Nick,
thanks for the answer, here the situation:
- firewall test done today and pass
- in both cases 3cx to external and 3cx to 3cx there's a normal two way audio call
- when I call from Teams to 3cx/external, i can hear, but the call receiver cannot hear me.
OK, so this narrows things down to Teams, which is good.
I am going to ask the obvious here, but have you checked the mic settings on the Teams client and the mic in general that it works?
If that's OK, please do 2 more quick tests. From the Teams client:
  • Call *777. This is the 3CX Echo Extension, if you talk, do you hear your voice back?
  • From your Teams client, if you call another Teams user, do you have 2-way audio there?
mic volume is ok.
- callin *777 i cannot hear my voice back
- teams to teams (calling the 3cx extension and answering in teams) same thing, the receiver cannot hear
Sorry if I wasn't clear on that last part, I mean calling directly via Teams, without going through 3CX.
a normal call teams user to teams user works fine
I'll send you a PM shortly.
Just for others reading this post, the issue turned out to be a routing issue between the 3CX server and the internet that was affecting only Teams.
After correcting this, the issue was resolved.
