Solved p asserted id
juice1
New User
for billing purposes i need to send P-asserted ID to my provider in the form "[email protected]"
I tried adding this to the extension and sending as outbound caller ID taken from extension, however they are receiving as "+44XXXXXXXXXX%40sip.domain.com"
with the @ sign replaced by %40
Any idea how I can send in the correct format? thanks
actually I think I just need to sort out the host part, I will try that and confirm.....thanks
yeah all good, was trying to add the host part on the caller id........just needed to implement a custom host field instead....ta
Reactions: YiannisH_3CX
LeeonLau
