Participant Camera control
fbremote
Hi. In the web conferencing, we've noticed that the Organizer has the ability to remotely disable / enable remote participant's cameras. This could be... problematic to say the least.
Is there a way to restrict this permission so that local camera control is only through the user?
Thanks!
We're aware of the downsides of the ability to remotely enable/disable another user's camera. We've been considering changing this slightly by adding a confirmation dialog on the participant's side in the case an organizer wants to enable someone else's camera/mic.
We'll likely be adding this or a variant of it sometime very soon.
Ok. If it matters at all, our 2 cents is that there should be a global role setting for control/blocked, and if control is allowed, the organizer can only turn the camera off, not on.
Thanks.
Reactions: Milez
Thanks for your feedback. We'll look into how this will work exactly as to not impact users negatively with changes to this functionality.
Graham Robertson
