Solved Portal API token is not valid
perrys1170
New User
Good morning,
I am using webinar on wordpress. with 3cx v18.
from the management console I go to settings/ conferancing/ video/ API and generate an API for the webmeeting API token
webneeting FQDN: myfqdn.de.3cx.net
webmeeting API token: pasted here making sure not to add and blank spaces
I keep getting the following error.
  • Portal API token is not valid.
I've searched everywhere for the solution buts seems they're all outdated. Please help!
Good morning,
the WordPress plugin is currently for 3CXv16.
v18 has a complete Rest API, for now, https://documenter.getpostman.com/view/17439253/UUxzBnmk which allows a do it your self implementation on your website (in case you are a coder). The update and move of the WordPress Plugin to v18 is something we might do until the end of the year for consumers.
Good morning,
This is also in our plans. The current one is wayy too limited and didn't work correctly most of the time (at least for us.)
@perrys1170
we have a beta version of the upcoming plugin compatible with v18.
Would you like to give it a test run?
Hello there;
I have updated the webinar in wordpress for V18 and I have scheduled a webinar but it is not showing on the page. I was using V16 but it still doesn't work now, can anyone run it?
@MuratDemirtas
I assume you have inserted your HTTPS URL to your system (incl. port if not 443) and added the correct API key from the Settings > Conference > 3CX API key section into the configuration.
@StefanW
Yes, wordpress webinar does not give an error message and I create webinar in the account of the subscriber number I wrote and it comes up empty on the www.trakyatelekom.com/webinar page.
we uploaded a new version of the WP plugin.
In this version, you can now directly test the API call to your 3CX System and evaluate the filtered data.
May this helps to debug your case in a convenient manner
Hello there;
Thank you for this information, I tested it but I am getting the following error, everything seems normal but why am I getting an error?
"result": false,
"error": "404 Not Found",
"errorcode": 404
Hello there;
"result": false,
"errorcode": 404
Hi, I will send you a PM shortly to ask you for some information.
@MuratDemirtas thank you for the access to my Team Member, we identified the issue and will be updating the plugin shorty.
Reactions: MuratDemirtas
Hello there @StefanW ;
You're welcome, I'm glad it was helpful. I was using it on the training page of my website, it's good that it will work, I plan presentations to potential customers from here all the time.
Try updating the plugin through WP-Admin and you should see 18.2.3. That should address your issue.
Let us know how it goes please.
Reactions: NickD_3CX
Excellent, thank you for confirming!
Graham Robertson
