Salesforce
Soli
Platinum Distributor
Is there a way that the template drop search in leads field in salesforce?
I got this message but i dont have a license for form leads in my salesforce
Server returned a non successful status code - HTTPStatusCode=BadRequest - Reason=Bad Request - Content=[{"message":"sObject type 'lead' is not supported. If you are attempting to use a custom object, be sure to append the '__c' after the entity name. Please reference your WSDL or the describe call for the appropriate names.","errorCode":"INVALID_TYPE"}]
System.Exception: Server returned a non successful status code - HTTPStatusCode=BadRequest - Reason=Bad Request - Content=[{"message":"sObject type 'lead' is not supported. If you are attempting to use a custom object, be sure to append the '__c' after the entity name. Please reference your WSDL or the describe call for the appropriate names.","errorCode":"INVALID_TYPE"}]
You can create your own version and remove the parts you don't want.
Reactions: edossantos
