Since update to Android 9 3CX Android Client issue
SvenBrett
Platinum Partner
we use the 3CX V16.
On my Sony Xperia XA2 Ultra, I have installed the 3CX Android App from the Google Play Store
Everything went well so far.
Since the update from Android 8 to Android 9, I can only perform incoming phones with the app. Outgoing calls are indeed signalized, however, you only hear fragments to nothing.
Is the problem known somewhere?
Another employee has exactly the same problem. Everything worked fine with Android 8. Since he has a new phone with Android 9, it also does not work
Mahlon
