SIP trunks not registering on https://1299.3cx.cloud/
melbourne
We have 2 customers on the above free version 3CX address, both customers SIP trunks are not registering.
The response from the service provider is as per below:
The trunk REGISTER is currently reaching us, we challenge for auth and the trunk sends the same REGISTER without auth. We receive the REGISTER, send a 401 back to the 3CX to challenge for auth and the same REGISTER (without auth) is sent so it is just looping.
Either:
1. The PBX is not currently configured to respond to 401 auth challenges
2. the 401 challenges aren't making it back/are being blacklisted by the 3CX
Can someone from 3CX assist us with this issue?
@melbourne option 2 you mentioned is the case as option 1 is implemented on the PBX.
When the PBX sends out a Register with Sequence 1, you send 401 or 407 and the PBX does not
send out Register with Sequence 2 (keeps sending with Sequence 1 again) , this means that the trunk ip is Blacklisted on the PBX side. Check the Sequence numbers you receive.
Reactions: melbourne
This is a free version; there is not much I can do from our side I believe.
This is the fault when I run a test on the trunk:
Detected Issues
Registrar 'sip.melbournetelecom.com.au' is in Auto-discovery but does not resolve to any NAPTR or SRV records. Specify a SIP port to skip useless DNS lookups.
The SIP Registration attempt got a failure response [forced unregister] at 5/18/2026 7:16:14 PM +10:00
Report as requested
<report level="Info">
<![CDATA[ Main trunk number '61391081222' Registrar sip.melbournetelecom.com.au has a DNS HOST record (sip.melbournetelecom.com.au) resolving to: [203.57.203.65] IP Mode: IPv4 Selected server address: 203.57.203.65:5060 Selected transport type: UDP Selected server domain: sip.melbournetelecom.com.au ]]>
</report>
<report level="Warning">
<![CDATA[ Registrar 'sip.melbournetelecom.com.au' is in Auto-discovery but does not resolve to any NAPTR or SRV records. Specify a SIP port to skip useless DNS lookups. ]]>
</report>
<report level="Error">
<![CDATA[ The SIP Registration attempt got a failure response [forced unregister] at 5/18/2026 7:16:14 PM +10:00 ]]>
Is this a supported sip trunk for the free pbx? Which template did you use to configure the trunk?
Yes, it is. VOCUS
Which template did you use? Is this the standard or busines trunk?
The problem has been resolved.
Thanks for your help.
I think 3CX had blacklisted
