Snom PA1 - Does it have aux out?
Alphabetic
3CX MVP
Just checking before we look to buy it.
Customer has amp with speakers and the current phone system has aux out to the amp.
Does the PA1 have aux out so I can do the same connection?
thanks.
I think this should help:
With audio equipment there are some other parameters to consider (Ohms, etc) but I am not an expert on this so I think you should check the snom PA1 spec sheet for all the details.
