Supported Fanvil Device Inconsistencies
RichB
SOHO User
A while back I asked if the V series phones were going to be supported and it was basically suggested that the V62,64,65 were but the V67 wasn't possibly due to being Android based. Then yesterday I saw a post with someone saying that they were having difficulty with their i56A indoor station and I thought that's never going to be supported it's Android based, I check the website and to my surprise it's supported. So one Android device supported another not. The other indoor phones i51W, i52W, i53W not supported even though they run a firmware almost identical to every other Fanvil phone. Then you start to look at other devices i16S/V, i18S supported, i16V not but runs the same firmware. i20S, i23S, i30, i32S supported, i32V,i33V/VF not but runs the same firmware. Why is it so inconsistent? It seems like you just didn't receive a freebie to be able to test or that you need a large enough partner or customer to complain about it.
Yealink T57 it android and is supported, works fine we have some the VP59 isn't listed however but also runs Android. Hopefully they will support the V series they are sharp phones.
The T57W still uses a Linux-based OS. The T58W (Pro) does run Android, like the T58A before it, and VP59.
Having more support for Android phones like V67 would be great, since they are usually much better for supporting video calls with intercoms or 3CX Apps for example.
Teemal
