Teams Direct Routing - Outgoing call rejected, caller is unknown
rwgmbh
Hi Everyone,
we set up Teams Direct routing and Incoming Calls to teams are fine.
Outgoing calls (wheter to internal or external) are failing with teams showing "rejected" after one ring.
I found this Post which is showing the exact same problem, but unfortuanly the solutions (having no call id policy set) does not work for me
I dont have any Caller ID policies set.
I tried all ideas on the troubleshooting FAQ but nothing of that did solve my problem.
Thanks for your help.
05.01.2022 09:28:33 - [CM503013]: Call(C:38): Incoming call rejected, caller is unknown; msg=Invite-IN Recv Req INVITE from 52.114.76.76:2176 tid=bc52d7c8 Call-ID=6dc580350ebb544f988a333c22935332:
INVITE sip:22@cti.COMPANY.de:5061;user=phone;transport=tls SIP/2.0
Via: SIP/2.0/TLS 52.114.76.76:5061;branch=z9hG4bKbc52d7c8
Max-Forwards: 70
Record-Route: <sip:sip-du-a-eu.pstnhub.microsoft.com:5061;transport=tls;lr>
Contact: <sip:api-du-c-euno.pstnhub.microsoft.com:443;x-i=9c0e3bfe-d6c6-48b0-99f0-b257abc03ec5;x-c=6dc580350ebb544f988a333c22935332/d/8/04f908a6bf9a473d9809c8e43416e061>
To: <sip:22@cti.COMPANY.de:5061;user=phone>
From: "Company Worker"<sip:+49XXXX;ext=[email protected]:5061;user=phone>;tag=ecd23492bfc74c6da75cce1295bf04a4
Call-ID: 6dc580350ebb544f988a333c22935332
CSeq: 1 INVITE
Session-Expires: 3600
Min-SE: 300
Allow: INVITE, ACK, OPTIONS, CANCEL, BYE, NOTIFY
Content-Type: application/sdp
Supported: timer
User-Agent: Microsoft.PSTNHub.SIPProxy v.2022.1.3.2 i.EUNO.12
Privacy: id
P-Asserted-Identity: <tel:+49XXXXext=21>
P-Asserted-Identity: <sip:[email protected]>
Content-Length: 1093
v=0
o=- 405887 0 IN IP4 127.0.0.1
s=session
c=IN IP4 52.113.116.0
b=CT:10000000
t=0 0
m=audio 49980 RTP/SAVP 104 9 103 111 18 0 8 97 101 13 118
a=rtcp:49981
a=ice-ufrag:Mr0i
a=ice-pwd:gDrreaYpvSZIF5K3W0iNQQUq
a=rtcp-mux
a=candidate:1 1 UDP 2130706431 52.113.116.0 49980 typ srflx raddr 10.0.97.82 rport 49980
a=candidate:1 2 UDP 2130705918 52.113.116.0 49981 typ srflx raddr 10.0.97.82 rport 49981
a=candidate:2 1 tcp-act 2121006078 52.113.116.0 49152 typ srflx raddr 10.0.97.82 rport 49152
a=candidate:2 2 tcp-act 2121006078 52.113.116.0 49152 typ srflx raddr 10.0.97.82 rport 49152
a=label:main-audio
a=mid:1
a=crypto:1 AES_CM_128_HMAC_SHA1_80 inline:7+McTZMT4Hv2tN9aQjxPYMcbWniX3caVlrLkJEbq|2^31
a=sendrecv
a=rtpmap:104 SILK/16000
a=rtpmap:9 G722/8000
a=rtpmap:103 SILK/8000
a=rtpmap:111 SIREN/16000
a=fmtp:111 bitrate=16000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:97 RED/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:13 CN/8000
a=rtpmap:118 CN/16000
a=ptime:20
Hi!
The first thing I would check is if the certificate you have used is correct. A pretty accurate online tool to check this is here:
https://www.sslshopper.com/ssl-checker.html
Just enter the Teams FQDN (I think you are using the same as for the PBX as it is custom...) and put ":5061" at the end. If there are any error here, you should consider fixing them before going any further. Most common problem is not including the correct intermediate certificates.
Next I would check in the Teams Admin page to see if the "Direct Routing" status of the connection is OK.
Another thing to check is, in the 3CX Management Console, if you search for the Caller extension, does it show the correct "Synced with" type?
Generally a very useful article to go through is this:
https://www.3cx.com/docs/microsoft-teams-integration-faqs/
Stephan Eusebe
