Transfer call to external number using Teams client fails
KjetilSorby
Gold Partner
Hi!
We have some difficulty transferring calls to external numbers using the Teams client with 3CX V18.0 (Build 444).
Any idea what we are doing wrong? :)
Hi!
Could you walk us through the exact call scenario you are having the problem with?
Examples:
  1. 3CX Ext A calls Teams Ext B
  2. Teams Ext B Blind Transfers to External Number and the call fails
Or
  1. External Number calls into 3CX
  2. Call is answered by 3CX Ext A
  3. 3CX Ext A BXfers to Teams Ext B
  4. Teams Ext B BXfers to another External number and the call fails
Also check that this Teams client that you have synced with 3CX can make External Calls directly without transferring.
Hi!
Examples:
Or
Senario: Teams Ext A receives a external call and wants to transfer the call to a mobil number (external number). That fails. And yes, we can make external calls using Teams client. We can also park and call outbound but not transfer.
This scenario:
  1. Incoming External Call rings 3CX Teams Synced extension
  2. 3CX Teams Synced Extension Answers call
  3. 3CX Teams Synced Extension BXfers call to another External Number
should work fine.
I suspect that if it isn't being forwarded, that it is because of the Outbound Rules that might be too restrictive.
Could you send a screenshot of your Outbound Rules?
Also, try this:
1. Switch 3CX Logging to "Off" from Dashboard --> Activity Log --> Settings
2. In the Dashboard --> Activity Log press "Purge" to delete the current logs
3. Go back to Dashboard --> Activity Log --> Settings and enable "Verbose"
4. Replicate the issue
5. Go to Dashboard --> Activity Log and the Logs there should show you what happened
Try to do this at a time when the system isn't busy so that there aren't logs from other calls to make things easier.
Stephan Eusebe
