Using Elastix as a PSTN Gateway
BiancaA
Bianca Allery submitted a new blog post
Something similar could be used for GSM, but which version of Elastix?:confused:
http://www.elastix.org/community/threads/chan_dongle-no-outgoing-audio-2-5-0.131547/
Spanish Technical Articles can be placed in Español section?
Hi Thelev,
If you are using analog PCI interface card such the one from Digium, Sangoma, OpenVox, and others you can keep using them. If you have an old system running for example elastix version 2.5 or other versions where you could detect these cards, then you can convert it as PSTN gateway as explained on the guide and integrate it to the new telephony system server.
Best regards!
Themarketmindset
