V18: Webmeeting settings not saved
VSC
Forum User
With V18 the user seetings are not saved. In V16 always the last settings were autosaved. Especially the first setting leds to problems as we usually have this deselected. Is there a way how I can preset a default in the 3cx management console?
Hi!
Unfortunately the options that are selected and predefined and hardcoded, but you could make a simple page/app that uses the 3CX Video Conference API to create meeting exactly as you want them, with the option you want.
"... options that are selected and predefined and hardcoded ..." is nothing you want read as a customer shortly after you upgraded to V18 :-(
Especially as it worked before ...
I am pretty sure that they were also hardcoded in V16 too, just some default settings were changed between V16 and V18, so that's why you might have this impression.
Anyhow, the suggested option for having "custom" settings at the time of writing is to use the 3CX Video Conference API.
VOIPEric
