VideoConference on Mobile without APP
FirstPoint
Titanium Partner
is it possible to view the confcall directly without downloading the app? By making the page display on the mobile phone as if it were a pc?
Simo
Simo
Unfortunately, no. Most mobile browsers don't support WebRTC full-featureset that's used in WebMeeting.
Actually adding the param ?web=true to the url, you can use the web based app on mobile.
But as mentioned before it will work correctly only in few cases, basically chrome on android.
Also the user interface has not been designed specifically for the mobile, then you can have some issues on small devices.
Open a new chrome tab, switch to desktop mode, and paste in the meeting link. Should work fine, I use it occasionally for testing when I'm away from my PC. The performance is fine on my s22 ultra. This is not a supported method, so keep in mind that function and performance may not be perfect.
Reactions: FirstPoint
Graham Robertson
