WEBMEETING MISSING
Softserv
Trainee Partner
When I open a webmeeting some messages appearing MISSING appear in all fields .. Any suggestions?
Try populating your extension's first/last name and e-mail fields and try again.
I just redo it, it didn't work out.
I just redo it, it didn't work out. I realize that when I look for the webmeeting IP and blacklist it to allow it, it says that the IP is already blacklisted, even though it is blank. May have to do?
The WebMeeting IP is whitelisted by default. You won't be able to see it because it's hidden. This is not the problem.
Can you PM me the meeting link you're trying to use? I'll take a look and see what might be wrong.
I send the link by message
hello
I'm having the same problem, any room i create all fields are like missing.
Graham Robertson
