Whatsapp Report / Log
Johnson Tan
Titanium Partner
Is there a way for supervisor to monitor the WhatsApp log (similar with the chat)?
I could not find it from the management console.
Thank you in advance.
Regards
JT
WhatsApp messages have chat logs, Check under the management console > Reporting > Chat logs
Hi Charles,
Thank your for your response.
I have tried to search on reporting to view the WhatsApp log but could not find (as per attached).
Can you enlighten me on this matter?
Regards
JT
i cant find this either
Please check that in the Management Console Dashboard, Chat Logs are enabled as per the below screenshot. Then the Chat Logs section should appear in the Reports Tab.
If so then Check under the management console > Reporting > Chat logs
Hi Charles, got that..thank you for the clarification.
Reactions: Charles_3CX
You are welcome.Glad i could help
