Yealink T4x Series IP Phones - Disabling older SSL/TLS
B Garfitt
I have seen some older posts (2017) relating to disabling older SSL/TLS features for the web interfaces on the Yealink T4x Series IP Phones.
sip.tls_cipher_list = AES:!ADH:!LOW:!EXPORT:!NULL
security.tls_cipher_list = AES:!ADH:!LOW:!EXPORT:!NULL
However, I was wondering if there has been any more recent information concerning disabling these older connection methods (for vulnerability scanning) without resorting to editing the templates and thus making the system a minefield for 3CX support due to using custom templates. In a lot of cases, we VLAN off IP Phones on a network which resolves this issue, however, we have a couple of sites where VLANs are not able to be implemented as a solution here.
Is there a feature for restricting access on a Yealink T4x Series IP Phone from only a certain range of IP Addresses?
If updating the template to disable older ciphers is the only option here, then that is not a huge issue but I would like to avoid it if possible.
Thanks in advance
Hi!
Generally we get most of the template changes to the phone templates from the manufacturers.
Here though you are describing 2 different things:
1) Restricting access from only a certain range of IP Addresses
2) Disable older ciphers
For the #1, I don't happen to know if it's possible.
For #2, I think you should raise your concern with Yealink and if they deem it necessary, will provide us with an updated template.
Generally though I don't think we provision those parameters, which means that if you provision your Yealink from a Factory Reset state using the default template, those values should be the default.
This also means that if you manually make a change through the phone interface, reprovisioning the phone won't overwrite those settings.
Finatra.us
