Solved yet another webmeeting report details question
Filmarte
good evening to all
Does anyone know if it is possible to have more detailed reports on web meetings? To be more specific: I would like to have the login and logout times and not just the percentage on the whole meeting duration. I would also like to have more space at the login field for each participant to be able to fill with more details. Currently there is enough space for name, surname and a few more spaces but it would be useful to be able to fill with ID number and/or our "fiscal code". I'm using it for financed training and I need more details.
Maybe it is possible to intercept the "report" of the external servers to the 3CX, to be able to extract the needed infos?
thank you
Regards
Filippo
Hi Filmarte,
build in are no further reports available. An option could be to use the RestAPI of VC and query periodically the get meetings endpoint. Save the results somewhere (external database) and then use this as a base for reports.
Reactions: NickD_3CX
Thank you very much Stefan I'll dig it to see what can be done.
Best wishes
Filippo
Graham Robertson
