in-band DTMF tone detection is turned off.
paul-cdma
[MS211000] Call(19) Ext.500: DTMF (RTP) from ***** arrived. in-band DTMF tone detection is turned off. :x
HOW to switch it ON?
This just means that your phone is not sending DTMF using inband, It tries to send DTMF using RTP(RFC 2833) . If you wish to change this, you just have to configure your phone/extension to use inband (if it supports it - because some phone only support RTP or SIP info)
It is not really switched off. Its just not using that method.
Ok thank`s I use xlite client. maybe the problem is in this soft phone
I too am having the same problem when we call in from a cell phone.
Here is the message from the server logs. Most of our clients will come
into the system thru cell phones or blackberry's. How can we fix this issue
sence we can't change settings on mobile phones??? Everything works fine
comming to our provider but when we put the 3CX in the middle the
problems begin.
ecwilson
[MS211000] Call(17) Ln:10000@VocalocityPBX - L1: DTMF (RTP) from 64.57.251.7:14836 arrived. in-band DTMF tone detection is turned off.
problems begin.
ecwilson
Which kind of problem do you have. What is not working?
We can't get into the voice mail system & we can't get to any of the
extensions from the outside (the normal callers come in) The system
tells us some type of IVR problem & then disconnects.
ecwilson
Please specify those "some" problems.
Thanks,
Stepan
When you call into the system it plays the greeting & when you press
1 to transfer to ext 100 the system tells you their is a IVR problem.
Also when I dial the 999 I receive the same error message.
ecwilson
Still having the same problem.
When I call into the system the system it tells me error in IVR
session & then hangs up. Calls in & out are fine but two of the
grandstreams don't ring now. I will do another factory reset to
see if that clears things up. :x
ecwilson
Still having a ext100, ext101 ringing problem.
Also IVR problem is still their when I dial 999.
ext100 to ext101 does not ring
ext100 to ext102 works
ext101 to ext100 does not ring
ext101 to ext102 works
ext102 to ext100/101 does not ring :?:
13:23:49.559 StratInOut::onCancel [CM104009] Call(46): Call from Ext.102 to 999 has been terminated
13:23:42.746 MediaServerReporting::DTMFhandler [MS211000] Call(46) Ext.102: DTMF (SIP INFO) from 00.00.00.00:5004 arrived. in-band DTMF tone detection is turned off.
13:23:33.574 CallLegImpl::onConnected [CM103001] Call(46): Created audio channel for Ext.102 (00.00.00.00:5004) with Media Server (00.00.00.00:7092)
13:23:17.949 CallConf::onIncoming [CM103002] Call(46): Incoming call from 102 (Ext.102) to sip:[email protected]
13:22:55.637 StratInOut::onCancel [CM104009] Call(45): Call from Ext.102 to 999 has been terminated
13:22:48.855 MediaServerReporting::DTMFhandler [MS211000] Call(45) Ext.102: DTMF (SIP INFO) from 00.00.00.00:5004 arrived. in-band DTMF tone detection is turned off.
13:22:40.543 CallLegImpl::onConnected [CM103001] Call(45): Created audio channel for Ext.102 (00.00.00.00:5004) with Media Server (00.00.00.007088)
13:22:25.246 CallConf::onIncoming [CM103002] Call(45): Incoming call from 102 (Ext.102) to sip:[email protected]
13:20:22.855 StratInOut::onHangUp [CM104007] Call(44): Call from Ext.101 to 102 has been terminated by Ext.101; cause: CANCEL; from IP:00.00.00.00
13:20:20.215 CallConf::onProvisional [CM103003] Call(44): Ext.102 is ringing
13:20:19.887 CallConf::onIncoming [CM103002] Call(44): Incoming call from 101 (Ext.101) to sip:[email protected]
13:20:10.621 StratInOut::onHangUp [CM104007] Call(43): Call from Ext.100 to 102 has been terminated by Ext.100; cause: CANCEL; from IP:00.00.00.00
13:20:07.840 CallConf::onProvisional [CM103003] Call(43): Ext.102 is ringing
13:20:07.434 CallConf::onIncoming [CM103002] Call(43): Incoming call from 100 (Ext.100) to sip:[email protected]
13:19:58.652 StratInOut::onHangUp [CM104007] Call(42): Call from Ext.100 to 999 has been terminated by Ext.100; cause: BYE; from IP:00.00.00.00
13:19:52.652 CallLegImpl::onConnected [CM103001] Call(42): Created audio channel for Ext.100 (00.00.00.00:5004) with Media Server (00.00.00.00:7076)
13:19:37.262 CallConf::onIncoming [CM103002] Call(42): Incoming call from 100 (Ext.100) to sip:[email protected]
13:19:20.434 StratInOut::onHangUp [CM104007] Call(41): Call from Ext.101 to 999 has been terminated by Ext.101; cause: BYE; from IP:00.00.00.00
13:19:15.418 MediaServerReporting::DTMFhandler [MS211000] Call(41) Ext.101: DTMF (SIP INFO) from 00.00.00.00:5004 arrived. in-band DTMF tone detection is turned off.
13:19:00.105 CallLegImpl::onConnected [CM103001] Call(41): Created audio channel for Ext.101 (00.00.00.00:5004) with Media Server (00.00.00.00:7072)
13:18:44.652 CallConf::onIncoming [CM103002] Call(41): Incoming call from 101 (Ext.101) to sip:[email protected]
12:56:41.480 StratInOut::onCancel [CM104009] Call(40): Call from Ext.102 to 999 has been terminated
12:56:34.387 MediaServerReporting::DTMFhandler [MS211000] Call(40) Ext.102: DTMF (SIP INFO) from 00.00.00.00:5004 arrived. in-band DTMF tone detection is turned off.
12:56:26.105 CallLegImpl::onConnected [CM103001] Call(40): Created audio channel for Ext.102 (00.00.00.00:5004) with Media Server (00.00.00.00:7068)
12:56:10.637 CallConf::onIncoming [CM103002] Call(40): Incoming call from 102 (Ext.102) to sip:[email protected]
12:55:11.418 ServRegs::onAdd [CM113002] Registered: Ext.102
12:55:10.996 ServRegs::onRemoveAll [CM113004] Unregistered: Ext.102
ext100 - grandstream 2000 (demo setup)
ext101 - grandstream 2000 (demo setup)
ext102 - grandstream 2020 (live office phone)
ecwilson
VOIPEric
