После обновления на 16 версию ошибка в логе 3cxSystemService
dizel
Добрый день. Объединили CRM 1c и 3cx после запросов reportcall выходит erro. Что за ошибка? я так понимаю из-за пустого ответа на post запрос?
2020/04/17 08:38:32.756|4908|0007|Verb|Enqueue Updated.REGISTRATION.2
2020/04/17 08:38:32.757|4908|0006|Verb|Dequeue Updated.REGISTRATION.2
2020/04/17 08:38:32.762|4908|0030|Trac|GetTemplateFor(registrar=Wregistration.2: - Wextension.86: 132 - [ V4 192.168.0.66:5060 UDP flowKey=1048 transportKey=1 ] - 17.04.2020 5:38:37 - Panasonic-KX-HDV100RU/01.064 (080023e19930), ext=)
2020/04/17 08:38:32.763|4908|0030|Trac|GetTemplateFor(ext=Wextension.86: 132)
2020/04/17 08:38:32.763|4908|0030|Warn|HD: Detected invalid registration sip:[email protected]:5060. Searching HD device..
2020/04/17 08:38:32.763|4908|0030|Warn|HD: HD device is not found for registration sip:[email protected]:5060. Do nothing...
2020/04/17 08:38:33.142|4908|0028|Verb|The response is: ''
2020/04/17 08:38:33.142|4908|0028|Verb|Continue with empty matching.
2020/04/17 08:38:33.144|4908|0028|Erro|Exception during call reporting: System.NullReferenceException: Object reference not set to an instance of an object.
at CrmIntegration.ResultVariableScenarioProcessor.ProcessFinalResult(ProtocolScenario scenario, IValueManager valueManager)
at CrmIntegration.ScenarioProcessorBase.ProcessMatching(ProtocolScenario scenario, MatchingPath matching, ResponseMatcher responseMatcher, IValueManager customManager, HashSet`1 distinctMatchings, CancellationToken token)
at CrmIntegration.ScenarioProcessorBase.ProcessFoundMatchings(ProtocolScenario scenario, IValueManager customManager, List`1 matchings, ResponseMatcher responseMatcher, CancellationToken token)
at CrmIntegration.ScenarioProcessorBase.ProcessScenario(ProtocolScenario scenario, IValueManager customManager, CancellationToken token)
at CrmIntegration.ScenarioProcessorBase.Execute(ProtocolScenario scenario, CancellationToken token)
at CrmIntegration.CrmProcessor.ExecuteScenarioByName(String scenarioName, IEnumerable`1 parameters, Boolean useNoAuthProvider, CancellationToken token)
at CrmIntegration.CrmProcessor.ReportCall(CallEndedEvent call, CancellationToken token)
intoxtech
