0 Simultaneous Calls / License Expired
ianandrews
I have a V20 system where they cannot recieve calls, and can only make calsl via the app,
The license is showing as expired with the following error message:
_i18n.LicenseHttpsErr_InvalidTrustedStorage
Does anyone know what this means? We've checked the google backups and they are fine.
Which version (build) your are? Firewallcheck is green?
Version 20.0 Update 2 (Build 715 Release)
Firewall is ticked green.
There is your Problem, update 2 is way to old. We are on update 5! Now you need to take an backup and restore to a new vm with the newest update.
Thanks, we had auto updates turned on but it showed update 3 as alpha release, when we rebooted the PBX, it showed is as an official release, we have brought it up to date manually and problem solved. thanks for your helpAllow
Reactions: bitn2
Its always a good idea to monitor your pbx for updates or any failure.
hpgitsupport
