12291 Error
jrivera98
The issue is that the CISCO 7940G is showing a message "HTTP connection closed." What does that mean?
Also, on 3cx Phone System Managment Console it has a "SIP Server/Call Manage
is there a way to fix this?
I have attached the message below.
07/09/2018 12:46:55 AM - [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from
User-Agent: Cisco-CP7940G/8.0 Content-Length: 0 ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
Hey Saqqara,
I did but I notice that it mention “
Note that these phones can not be used from a remote location or in combination with a 3CX in the cloud” so that means that I can’t use it via Google Cloud?
jrivera98
Hello @jrivera98
These are legacy devices and are not supported for remote operation. You can only use these devices in local environment. I would recommend using a fully supported device to avoid compatibility issues and be able to use the full feature set,
gmacinit
