15.5 SP5 vs 15.5 SP6 PUSH service
nitrox
Gold Partner
What it will be the main difference between 15.5 SP5 and 15.5 SP6 PUSH service?
Anyone from 3cx can explain why it should be better from 15.5 SP5?
regards.
nitrox
I saw something say that it will support PUSH for more than one device at a time per extension.
Hello @nitrox
Please note that there will be major improvements in the way Push works in SP6 but you will need to wait for the update to arrive to see what the differences are.
Reactions: nitrox
I saw the same but I would like to know if it will work for Android and iOS or just Android. More i would like to know if it will support "PUSH polling". If you are out of wifi range and you receive a call and than you become online getting wifi signal you loose the call because the application doesn't receive the push notification when the device is disconnected. You need to be online to receive the call of course but if you are online after some seconds that you receive the call you should get the second or the third push notification which wake up the application.
nitrox
Hello @nitrox
ok, thank you but I let you know that the success of your product it depends on the PUSH notifications. I am almost closer to install DECT cells instead of SMARTPHONE if the situation will not change in 3 months.
Any roadmap for SP6?
This info will be posted when the beta is released.
No point releasing a roadmap if after testing, the function is not included
Upgrade your WiFi would be my suggestion vs. dect and your mobiles will work better not just for 3cxphone but overall.
My WIFI is already upgraded. We have got a cluster wireless of cambium network and everything is working! Here we are talking about PUSH service and reliability and sometimes it's better not to write but to think. If 3CX is changing the PUSH service on SP6 probably it's because something it's not working well. What you think about that?
megalmazan
