Solved 16.1.0.41 deactivate account
tkSwaggyDaggy
Forum User
Hi guys,
in the last version of the app it was possible to deactivate the accounts/profiles.
Where is this feature in the new version? I really need this. Dont wan't to uninstall the whole app all the time.
Best Regards
Hi guys,
Best Regards
By long pressing on the active account a sub menu appears with options to Deactivate - Edit - Delete.
In case you are interested in not receiving PUSH you can just edit one of the available statuses (eg DND) and disable PUSH notifications for this status only. Once you configure the forwarding rules you can just switch between status Available and DND.
To add to what @aspostolis_3CX said, some screenshots below
1. Click on the Status
12618
2. Click the Edit icon on a Status that you wish to modify
12619
3. Disable PUSH for this Status
12620
So now whenever that Status is selected, PUSH will be off.
Thanks for the fast reply.
You can mark this as solved
RJenkinsROCK
