16.2.0.81 hearing loss when app tries to reconnect or a second call comes in
nobody
Android 9.0 XZ1 compact build 47.2.A.11.228
Well, I serveral times asked that if call is disconnected, and the Program switches the network from Mobile to Wifi or vice versa that the users on call should be notified, because otherwise when only silence will be present people will tend to hang up.
Now, with this version, if the call is beeing held, a continous repeating loud beep will be heard. So loud, I promise not only I will abandon the use of the 3CX app. The same happens when a second call on the 3CX line comes in while on the phone. Sound level a little lower, but still, inacceptable.
When the call is beeing held because of the loss of connection instead of a loud annoying beep, some soothing easy sound should be played instead of a tune which will damage you ears.
I dont know how other mobiles using the beta behave, but this is simply not acceptable. Ok for an alpha version. But for a beta?
Mahlon
