16.7.0.31: no audio when making calls if using the "Automatic" (Android decides AAudio or OpenSL)
nobody
Phone: sony XZ1 compact, OS: sony 47.2.A.11.228
PBX: 16.0.9
If I make an outgoing Call, regardless of a remote party or internal number, I have no audio if I selected "Automatic"(Android decides AAudio or OpenSL) previously in the audio options.
If I activate the speaker for a short moment after the call is established, audio works
I normally do not need AAudio (I dont even know if this is better or not), but I found this while looking for an option to increase the microphone gain.
Hi @nobody and thanks for your feedback.
AAudio is the more modern Android audio API but unfortunately not all devices fully support it, as seems to be the case with your device which should default to OpenSL. We have made a number of improvements on this front in the upcoming beta, so be sure to check it out when it's released.
SupportRock
