18.0.9.35 installer to restore a backup.
select25
SMB User
Hello ,
I am currently running into an issue with restoring a backup of my 3CX system. The backup was created on version 18.0.9.35, and when I attempt to restore it on my current installation, I receive the error message indicating that the backup is from a newer version.
To resolve this, I kindly request access to the Windows installer for 3CX v18.0.9.35 (or higher) so that I can reinstall and successfully restore my backup.
Details:
  • Current environment: Windows 10
I dont think this is going to happen.
Back in the day... you'd install v18 from the installer, run the updates from a fresh install and then restore your backup.
If you're not able to run v18 updates from the console then you're going to have to restore to v20.
note that v18 isnt supported.
v18 is eol... You need to restore to v20.
When that last update to 18 was released 3CX said they would not be creating an installer for it and it was only available via patch.
Windows 10 is also EOL of course unless you have an ESU license. At one point 3CX said they would require an Enterprise license to run on Windows, though I do not recall seeing anything about that, since.
Also v18 can't activate anymore.
VAYA
