2 site Bridge static and dynamic
KhaledQuenawy
if i have 2 server and i want to conntect them with Bridge .. but one of site have Static IP and the other no ( only dynamic ) so which one put it on Master and which one will be Slave ,,,
i think site with static should be Master Right ..
and if the slave ip change ( How much Time will be down time connection )
Hello @KhaledQuenawy
Since the slave server connects to the master server then the server with the static IP should be the master.
If the IP changes on the slave server there will be no downtime at all as the slave will send its new IP to the master server.
The only thing that will be affected is presence information until the DNS records update. Typically Standard and PRO licences have a TTL of 6 hours and the propagation of the DNS might take even longer. Enterprise licences have a TTL of 5 minutes.
Smax
