2FA is needed on systems not running on ms360
Stringmusic
I know this is a mute issue but I really think that 2FA is needed on all systems not running with ms360. As an admin, the last thing you want is someone luckily guessing a PSWD and changing the configs.
When could this be added to the next upgrade?
Thanks,
This has been discussed many times, 2fa is not in the roadmap.
If you have a complicated password, and with the standard security it will be hard to crack 3cx, as after three incorrect passwords you are locked out for 12 hrs
What Saqqara said, currently there are no plans to add this. Remembers though 2FA can also be done via Google SSO and we support that too.
Reactions: JohnS_3CX
If you restrict your admin console to certain IPs, then you have no worries at all.
megalmazan
