- Joined
- Feb 16, 2012
- Messages
- 44
- Reaction score
- 0
Why is it that you keep talking like I am doing something wrong? If you read all of the post you will see that I can set up this unit the way Grand Stream Support said to and it does work but the only way is putting 991,992,993 in the prepend box in the rule. If I hade more routs I could keep going (994,995,996,997,998). This way it works and if I call out line 1 the phone I call gets line 1 CID. As anyone could see doing this will only work for 3 lines not all 8.
What the trouble is that if I do not put the 99X #s in then the call goes out ch2 in the gateway but my 3CX trunk status shows in going out ch1. This is where the CID comes in I call out line 1 but the phone I call shows line2 CID. If I hang up (NO CALL ACTIVE) and call back with the CID that was passed to the receiving phone it comes in on line 2. Are you sure yours is not doing the something and just rolling over to the next line when you are calling into the other line?
Let me add this as well this is a post on this same borad. Take a look at it.
Re: Outgoing Calls from GXW4104
by sigma1 » Fri Nov 18, 2011 11:49 pm
The issue is due to their (Grandstream) built-in round robin load balancing idea (BAD). They are aware of it and they (we) are working on it with them before our exchange pile becomes higher than our building.Charles Ambrosecchia
CEO - SigmaVoIP/Sigma Networks
3CX Certified Professional
http://www.sigmavoip.com
