Solved 365 Integration
Alphabetic
3CX MVP
Hi Guys
When setting up the integration how does one configure 3CX so that it does not create duplicates of existing?
I want to be able to turn on the integration and have it use what's already there.
Hi @kieferschild,
Are you referring to extensions?
If so, you'll want to ensure that the email field in 365 matches the email field in your extensions. That way they won't duplicate.
Hi @kieferschild,
You'll want to ensure that the email field in 365 matches the email field in your extensions. That way they won't duplicate.
Hi Vasilis,
I checked that before I turned on the sync but it still created duplicates.
Hi @kieferschild,
Have you confirmed that the Principal Email is the same?
Hi @kieferschild,
I meant was the Principal Email field the same as the email address in 3CX prior to the sync?
Reactions: VasilisV_3CX
After closer inspection, the issue was resolved by @kieferschild.
devo.it
