3CX 15.5 Legacy APK File
hubertjagodzinski
Hi! I need to export apk for a Legacy version of 3CX Mobile App and i cant do it :(. Can you upload the directly download link for this apk file? We need this to share it on many phones... Greatings!
Why don't you install from google play? Having many phones is not the excuse to mirror. You will spend much more time doing this.
You need to also understand that the apk installation is something from the past now. So this link you showed here, will lead you to a dead end.
Now when you extract, you dont get an APK but an AAB. The aab is just another name for a zip file with apk files inside BUT each one is built to support arm os..Google standards.
Just go on google play. And let them install, rate, comment and do the whole drill.
But we use MDM (mobile device management) our customers do not have access for Google Play :(
is your mdm up to date.
because you are asking for something that was used 2 years ago.
Google told developers last august, that if they do not move to aab format, their up will be unpublished.
Does your MDM understand aab files Android Application bundles.
What if our customer is international corporation with thousands users? They will not update or change MDM only because it do not support .aab or Google Play.
One of our international clients is using 3CX for Android and groups are missing from statuses in last update. (This is one of the most important functions for them, without it its complete chaos in statuses.) They have to switch to 15.5 legacy 3CX app but we cannot get .apk file.
From the other hand... The best solution will be restoring groups labels in statuses in main 3CX for Android app. Maybe as an option in settings?
Reactions: hubertjagodzinski
No if they have thousand users then they will get a PROPER MDM that supports what google says.
Google says AAB please. No discussion. If you have thousand users, then they afford the best.
Check the beta - we have groups in a proper way.
Mahlon
