- Joined
- Sep 29, 2011
- Messages
- 8
- Reaction score
- 1
I am not sure that this problem is caused by 3CX phone provisioning, but need to rule out this possibility.
Found this in the provisioning config file:
The problem, that I encountered with the Fanvil X3U, is the following:
When I enable DSCP and set Audio DSCP to 46, Signal DSCP to 24, the Audio DSCP will not change from CS0 to EF (46) (RTP), but Signal DSCP reflects new settings and it is CS3 (24) (SIP) in the packet capture output.
Tried with VLAN and non-VLAN configuration - no difference.
I am just asking: Are there any hidden settings in the X3U phone provisioning that can affect Voice? I do not think so but just need to verify it with 3CX.
Thanks.
Code:
<QOS_CONFIG_MODULE>
<EnableVLAN>0</EnableVLAN>
<VLANID>256</VLANID>
<SignallingPriority>0</SignallingPriority>
<VoicePriority>0</VoicePriority>
<EnablePVID>1</EnablePVID>
<PVIDValue>254</PVIDValue>
<LLDPTransmit>1</LLDPTransmit>
<LLDPRefreshTime>60</LLDPRefreshTime>
<LAN_Port_Priority>0</LAN_Port_Priority>
<Enable_diffServ>0</Enable_diffServ>
<LLDP_Learn_Policy>1</LLDP_Learn_Policy>
<LLDPLearnPolicy>1</LLDPLearnPolicy>
<Singalling_DSCP>-1</Singalling_DSCP>
<VLAN_Recv_Check>1</VLAN_Recv_Check>
<CDP_Enabled>0</CDP_Enabled>
<CDPEnable>0</CDPEnable>
</QOS_CONFIG_MODULE>
Thanks.
