3cx app and Wifi
nicolesuisse
Device Info
Phone Model: [All device Android and Iphone]
Firmware Version: [NA]
App Version: [16.4.1.120]
Additional details
Handset: [Phone|]
Contacts: [Local]
Connection: [WiFi]
Server Information: 3CX Server installation details, Internal, External, network info etc
Server OS: [Linux]
Server version: Android 16.0.5.611 IOS16.1.2.86
We have devices Android or Iphones with 3cx App install and register. In 4G it's works perfectly.
But since we switch on WIFI (home, office, friends wifi,....) the sound is dirty and sometime the call notification never come.
below the printscren config :
Screenshot from 2020-09-03 17-39-08.pngScreenshot from 2020-09-03 17-39-21.pngScreenshot from 2020-09-03 17-39-31.png
Could you help me ?
Best regards,
This could be a problem within your ISP and or your router. My phone works very well on my cell carrier however WIFI no so well. I just turn off WIFI and it works just fine
I've try with some WIFI access point each time the same issue.
Best regards
no body to help me ?
hello,
We meet this issue with all android and Iphone for the compagnie (different Android device and Iphone).
We have try some different WIFI and different ISP (home, compagnie, ...) and always the same bad quality. In 4G it's working fine !
So there is something with Wifi and some parameters into 3cx
Same situation here - different 3CX PBX versions, Android app versions and Android phones since year 2016 on different wifi networks and most of time calls over 3G/4G connection are ok but over wifi sound has clicking noise and distortion. Also there are no difference on wifi location (company local or outside). I can't remember any such kind of problem using Windows app over wifi.
No issues on 4G and WiFi, I use next codec order:
PCM, G729, GSM
PCM, G729, GSM
We are using PCMa, PCMu, G729. Which SIP Transport method You are using for 3CX App?
Default.
SIP Transport: UDP
RTP Mode: Normal
iPhone - iOS13 & 14
DejanMDS
