3CX App Call Quality Issues
Rono
We're having issues with call quality especially on 3CX Android apps, the signal bars keep turning green, good quality, and red, poor quality, during the call,
thereby affecting audibility, and also 'scratchy' noises.
We're running 3CX version 16 on a Debian VM
Hi @VasilisV_3CX,
Thank you for your prompt response.
It happens on all mobile phones in our environment, both on Wi-Fi and LTE.
Also we have cases of Samsung A31 android 11 having to redial to be heard on both ends and still it isn't clear.
Calls outside the network, both parties, are however clear
3CX PBX Version: 16.0.1078 on a Debian 9 VM
Network Connection: Both Wi-Fi IPv4 and LTE
Both Same Network (MPLS) as PBX or either party outside the network
Hi @Rono,
What codec order do you have set in both the Management Console >> Settings >> General and the Management Console >> Extensions >> [the extension] >> Phone provisioning >> 3CX App?
Try and move GSM FR to the bottom, as well as G729. Have G711 U-Law and G711 A-Law at the top. Make sure they are the same in both the extension settings and the general settings of the PBX and try again. Does the quality get any better?
Reactions: Rono
Hi @Rono,
@VasilisV_3CX ,
Let me do this, test and get back to you
@VasilisV_3CX,
We're noting improvements, but kindly note that the signal levels ( bars) keep fluctuating during conversation, is this a coded issue?
Hi @Rono,
The signal quality wouldn't be based on codec orders. It would most probably be an unstable connection between the PBX and the App that would cause the bars fluctuating. Is the Android App on WiFi at the time?
Reactions: Rono
@VasilisV_3CX,
We did test both on Wi-Fi and LTE, the calls appeared stable though, but the bars kept fluctuating throughout the conversations.
Hi @Rono,
Can you confirm, does this mean that the issues with audio are resolved but you're still seeing the bars fluctuating or do you mean that the quality is still fluctuating with regards to the changes of the bars?
Stephan Eusebe
