3CX App iPhone devices not ringing
bitwiz
We're using an On-Premise 3CX PBX. All the firewall checks pass. I'm having a problem where iPhones running the 3CX app won't always ring. All of our android devices work properly. I read in the forum that it might be an encryption problem with Apple's push servers denying 3CX's choice of encryption method. I can SSH into the PBX if necessary. Where might I find information on what encryption is acceptable and what file to check/modify in the 3CX PBX?
Hi @bitwiz I wonder if you have checked the event logs in your system?
Could you please check if there is any event about the push notifications.
I get this... though it's for a Samsung phone.
Code:
Failed to send FCM PUSH to device samsung SM-G973U(Ext.1003). Received error from server: Status: BadGateway, Reason: Bad Gateway. Find more info at: https://firebase.google.com/docs/reference/fcm/rest/v1/ErrorCode
PUSH sender ID: 50021 09/22/2023 10:47:57 AM
It's the only error I see in the log related to push notifications, now I'm not sure what's going on.
it can be a networking issue where the PBX is unable to communicate with the Push servers.
Perhaps the Push servers were overloaded at the time, maybe it's not us?
You may try later, otherwise please open a technical support ticket so we can gather the logs and check further.
Okay, I'll watch it for a while. If it continues, I'll open a ticket. Thanks.
Reactions: Alejandro_3CX
You are welcome!
Jake_Southern
