Solved 3CX App not ringing
meepman
New User
Good morning all,
I setup a 3cx in AWS and have my soft phone connected to it I can make outbound calls but it's not ringing for incoming calls.
On my PC it works just fine I have no issues with incoming calls not ringing it's just on the mobile app.
I have my NACLS setup to allow inbound access to:
TCP - 5060, 5090,5061, 5001, 443, 2195-2197, 5228-5230
UDP - 5060, 5090, 9000-10999
Outbound: Allow all
When I allow all inbound traffic in the NACL it works fine with no issue but I also don't want to leave all ports open on it for security purposes.
My question is what port am I missing because I cannot find it anywhere
Hey @meepman
The ports required by 3CX are indeed the ones you specified. I'm just not sure about TCP 2197-2197 and TCP 5228-5230, why are those forwarded?
Also, both 443 and 5001 should not be required, only one of the two is your HTTPS port, you could check on which port you can reach the Management Console (https://abc.3cx.com:5001 or https://abc.3cx.com:443) and that would be your HTTPS port.
Regarding the issue you're facing, you should keep the following in mind:
When a call is made to a Mobile client, the 3CX PBX must be able to contact either Apples or Google's PUSH servers on TCP port 443. Since you are allowing all Outbound traffic that shouldn't be an issue, but is the return traffic allowed? The source port used by 3CX in this case would be a random high port so there is no specific port to allow. You might want to check the firewall type and if it allows return traffic by default or not.
Hey @meepman
I figured that's what the issue is, I don't have inbound ports open for the higher ports. Resolved it by allowing inbound ephemeral ports for the subnet
If anyone is wondering the fix I added an inbound rule to my network access control list to allow 32768 - 65535
Reactions: ChrisC_3CX
Glad to hear you were able to resolve the issue, but do note that we recommend deploying using the method described in our guide which will automatically take care of the required firewall configuration for you: https://www.3cx.com/docs/cloud-pbx-amazon-aws/
cvanderzwan
