3CX App now missing Car/Bluetooth option
FabscoGroup
Hi all,
Since my app updated, (now 18.1.3.132) it is now missing the Car/Bluetooth tick box option and as a result, I cannot click my headset to answer calls. Anyone know if there is a way to get this functionality back?
@rightplan Thanks for your feedback.
Could you kindly retry with the new beta we just released today (18.1.5.259)
Should you still replicate the issue, could you also provide me in Private Message the app's verbose logs in order to understand what's going on and help you out with your issue?
  1. Enable Verbose Logs: “Android App Settings (top left hamburger menu) > Settings > Advanced > Troubleshooting > Enable verbose logging”.
  2. Restart your device
  3. Reproduce the issue and “Send log report”: Android App Settings (top left hamburger menu) > Settings > Advanced > Troubleshooting > Send Log Report
hi @ThomB_3CX ,
thank for your reply.
I've just tested the new version 18.1.529, stil same issue. Car / bluetooth compatibily option still missing, I've sent the log via PM.
@rightplan thanks.
Logs received and under review
Reactions: rightplan
Hi Thom,
Something in the last few updates has stopped me being able to answer incoming calls in the Toyota (which used to be fine, as discussed above.) Phone rings (through the car audio) I press the steering wheel button to answer, ringing stops, I hear only silence, caller hears the ringing noise as if it was still ringing. Phone has answer/decline buttons, answer does nothing, decline drops the call. Nothing in the setup has changed, only the 3CX phone app. Is it possible to get an APK for previous releases so I can track down when the problem started?
Edit:
I've worked on this a lot today, trying previous apk installs. The key seems to lie with the Audio Subsystem API setting in the advanced setup section. Neither of the two settings work on the latest version, but if I choose automatic on 18.1.4.211 or on 18.1.3 versions (tried a few!) all works as normal.
Hi @JimB thanks for your feedback.
Could you kindly confirm that the problems are on the version 18.1.5?
Would it be possible to gather the app's logs whilst reproducing the issue. Would be even more beneficial if you could gather them from both 18.1.5 and 18.1.4. This would help us a lot in figuring out the issue in a more timely manner.
Could you also provide me in Private Message the app's verbose logs in order to understand what's going on and help you out with your issue?
  2. Reproduce the issue and “Send log report”: Android App Settings (top left hamburger menu) > Settings > Advanced > Troubleshooting > Send Log Report
Thanks, your help would be appreciated
Hi Thom, just heading off on vacation this afternoon, back at the beginning of the week after next - will give it my full attention as soon as I get back.
Finatra.us
