3CX backups using Veeam
vcit
I'm trying to set up Veeam backups but I noticed the repos don't have the dependency for the linux-headers for the current running kernel 4.19.0-24-amd64.
I do see some headers for previous versions in the /usr/src directory though.
I have the "http://repo.3cx.com/debian/1808 buster main" repo and "http://repo.3cx.com/debian-security/1808 buster main" repos only.
Anyone have any advice on this?
You are trying the client backup? I would backup the vm using veeam.
Reactions: Marconi
I agree with @bitn2, use Veeam to do a full backup of the machine. I have done this for various 3CX installations and it works very well.
I can't do a Veeam backup because the linux headers are required to install the agent in order to do the backup. The headers aren't installed, nor are they in the apt repo.
You don't need to install anything on the PBX to do the Veeam backup. How is the PBX installed? Which hypervisor?
This is not running on a hypervisor, we're running a bare metal. I'm following the errors Veeam is giving me, attached below. It's running on Debian 10 buster.
That won't work... Just use the backup function from 3cx.
understood, thank you
mazet
