Solved 3CX Blacklist configuration with Azure/O365
VictorSP
Platinum Partner
In our 3CX we have a very restrited Blaclisted IPs list (basically everything is denied, only just a few IP addresses are allowed). Testing the integration with O365 we've verified this configuration blocks the communication between 3CX and O365 (error "Real Time Notifications to Microsoft 365 changes will not work because it seems that HTTPS port forwarding is not configured....") but if we allow all the ip range it works.
Is there any list of IP range O365 uses that we should allow on the 3CX blacklist?
Regards,
Víctor
Reactions: VictorSP
Thanks @ConceptsWeb , tested and working!!!
If someone needs the same configuration, just export one rule from Blaclist IP and add this to the Json:
Code:
,{"ip": "52.159.23.209/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 52.159.23.209/32"}
,{"ip": "52.159.17.84/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 52.159.17.84/32"}
,{"ip": "52.147.213.251/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 52.147.213.251/32"}
,{"ip": "52.147.213.181/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 52.147.213.181/32"}
,{"ip": "13.85.192.59/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 13.85.192.59/32"}
,{"ip": "13.85.192.123/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 13.85.192.123/32"}
,{"ip": "13.89.108.233/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 13.89.108.233/32"}
,{"ip": "13.89.104.147/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 13.89.104.147/32"}
,{"ip": "20.96.21.67/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 20.96.21.67/32"}
,{"ip": "20.69.245.215/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 20.69.245.215/32"}
,{"ip": "137.135.11.161/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 137.135.11.161/32"}
,{"ip": "137.135.11.116/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 137.135.11.116/32"}
,{"ip": "52.162.219.103/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 52.162.219.103/32"}
,{"ip": "52.162.218.180/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 52.162.218.180/32"}
,{"ip": "52.229.38.131/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 52.229.38.131/32"}
,{"ip": "52.183.67.212/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 52.183.67.212/32"}
,{"ip": "52.142.114.29/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 52.142.114.29/32"}
,{"ip": "52.142.115.31/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 52.142.115.31/32"}
,{"ip": "51.124.75.43/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 51.124.75.43/32"}
,{"ip": "51.124.73.177/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 51.124.73.177/32"}
,{"ip": "20.44.210.83/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 20.44.210.83/32"}
,{"ip": "20.44.210.146/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 20.44.210.146/32"}
,{"ip": "40.80.232.177/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 40.80.232.177/32"}
,{"ip": "40.80.232.118/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 40.80.232.118/32"}
,{"ip": "20.48.12.75/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 20.48.12.75/32"}
,{"ip": "20.48.11.201/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 20.48.11.201/32"}
,{"ip": "104.215.13.23/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 104.215.13.23/32"}
,{"ip": "104.215.6.169/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 104.215.6.169/32"}
,{"ip": "52.148.24.136/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 52.148.24.136/32"}
,{"ip": "52.148.27.39/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 52.148.27.39/32"}
,{"ip": "40.76.162.99/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 40.76.162.99/32"}
,{"ip": "40.76.162.42/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 40.76.162.42/32"}
,{"ip": "40.74.203.28/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 40.74.203.28/32"}
,{"ip": "40.74.203.27/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 40.74.203.27/32"}
,{"ip": "13.86.37.15/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 13.86.37.15/32"}
,{"ip": "52.154.246.238/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 52.154.246.238/32"}
,{"ip": "20.96.21.98/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 20.96.21.98/32"}
,{"ip": "20.96.21.115/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 20.96.21.115/32"}
,{"ip": "137.135.11.222/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 137.135.11.222/32"}
,{"ip": "137.135.11.250/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 137.135.11.250/32"}
,{"ip": "52.162.219.149/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 52.162.219.149/32"}
,{"ip": "52.162.219.167/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 52.162.219.167/32"}
,{"ip": "52.151.30.78/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 52.151.30.78/32"}
,{"ip": "52.191.173.85/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 52.191.173.85/32"}
,{"ip": "51.104.159.213/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 51.104.159.213/32"}
,{"ip": "51.104.159.181/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 51.104.159.181/32"}
,{"ip": "51.138.90.7/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 51.138.90.7/32"}
,{"ip": "51.138.90.52/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 51.138.90.52/32"}
,{"ip": "52.148.115.48/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 52.148.115.48/32"}
,{"ip": "52.148.114.238/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 52.148.114.238/32"}
,{"ip": "40.80.233.14/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 40.80.233.14/32"}
,{"ip": "40.80.239.196/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 40.80.239.196/32"}
,{"ip": "20.48.14.35/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 20.48.14.35/32"}
,{"ip": "20.48.15.147/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 20.48.15.147/32"}
,{"ip": "104.215.18.55/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 104.215.18.55/32"}
,{"ip": "104.215.12.254/32","blocktype": 1,"expirationDate": "2041-11-10T16:08:14+00:00","description": "Microsoft O365 Graph - 104.215.12.254/32"}
Regards!
KylieWilderman
