- Joined
- May 17, 2018
- Messages
- 2
- Reaction score
- 0
Hi Support,
I recently took over a site which uses 3CX and I have no previous experience with 3CX. The site is having some issues with calls etc and when looking through the logs I see the following:
1. Call or Registration to XXXXX@(Ln.10002@Trunk to XYZ) has failed. IP Address replied: 503 Service Unavailable; from IP Address:5060
2. Call or Registration to XXXXXX@(Ln.10001@Trunk to XYZ) has failed. IP Address replied: 503 Service Unavailable; from IP: IP Address:5060
3. Call or Registration to XXXXX@(Ln.10001@Trunk to XYZ) has failed. IP Address replied: 404 Not Found; from IP:IP Address:5060
4. Call or Registration to 2@(Ln.10002@Trunk to XYZ) has failed. IP Address replied: 404 Not Found; from IP:IP Address.19:5060
5. Registration at Trunk to XYZ has failed. Destination (sip provider@provider:5060) is not reachable, DNS error resolving FQDN, or service is not available.
6. Device Mobile dialed on (AnyLine@Trunk to XYZ) had no available outgoing trunk(s) for Call(from "IP Phone"<sip:[email protected]:5060>;tag=826833034 to mobile number)
I have removed the clients number etc from the above for confidentiality.
One of the errors which is point 5 suggests DNS. I can confirm the site is not having any issues with DNS. I have also confirmed DNS settings on PC is correct. I have also rules out firewalls and any packet loss.
I suspect we have a few issues here.
1. The provider is having issues
2. Outbound call flow is not setup correctly as per number 6.
The SIP lines are Register/Account Based.
May i ask for people opinions on the following?
Regards
Regards
