3CX Chrome Browser Extension on a Chrome OS device
edfosho
... I just had to uninstall it. Had enough of it failing on me, using Chrome on a Chrome OS device (Google Pixel Slate).
I was using it earlier today and it kept randomly causing my webcam to flash it's indicator when I was checking settings. Making and receiving calls generally work well, though, occasionally it does need a 'reload' of the extension.
Really not convinced it's been tested on a Chrome OS machine - can anyone confirm if it's supported please?
Does anyone else have any experience with the Browser Extension on Chrome OS?
There is an incoming call audio routing issue if you use a hdmi secondary display and a headset for audio. With the webclient and extension both set to use headset you get zero audio, but if you go into the settings while on the call and change the settings to hdmi the headset works and outbound calls are fine both ways. No hdmi display works as intended. duplicated on a asus chromebox and a hp chromebook.
I didn't have any crashing issues, but honestly didn't test it much due to the audio issue.
I think the last chrome os update caused a lot of havoc. Its broke a few apps, not sure if its related.
gmacinit
