- Joined
- Aug 2, 2017
- Messages
- 17
- Reaction score
- 1
I've got a strange situation I'm trying to figure out.
Network setup:
Internet------FW------3CX Server-------FW1----LAN1 (IP Phones)
----FW2----LAN2 (Mobile devices)
I'm using split DNS so I can always use the companyname.3cx.us hostname. The actual IP of the server is 10.200.1.28.
Mobile devices with the 3CX client installed use wifi on LAN2, passing through FW2, which does NATing to it's 10.200.0.x address (note that this network is a /16, so this interface and the server are on the same subnet).
When a new extension is created, the system provisions a 3CX Client phone, and preselects 10.200.1.28 as the network interface for registering and provisioning. When the client is then provisioned, it thinks it should use 10.200.1.28 for the local IP, and companyname.3cx.us as the external IP. When using the carrier network or another external wifi network, everything works. Internally (on LAN2), however, it appears to signal correctly, but no audio passes in either direction.
Now, if I look at the device provisioning in the management console, I can change the interface to companyname.3cx.us, reprovision within the client, and everything works. This has me confused, as the FQDN correctly resolves the IP address.
So, first, can anyone explain the behavior I'm seeing? Second, if there's no good explanation or solution, is there a way to make sure 3CX uses the FQDN for the initial configuration, so it doesn't have to be manually changed?
Network setup:
