3CX crashing to desktop for one workstation
kriley87
Hi everyone,
We have a user experiencing hard crashes on 3CX. Its intermittent and there's no consistency to the crashes, so I wanted to reach out on the forums to see if anyone could help me isolate the problem.
So far I've re-provisioned the user's extension and also installed a higher version of 3CX. Unfortunately the issue still persists. Below is a snippet of the last crash log timestamp... I appreciate the help anyone can provide here!
[22.06.2021 16:09:23.903][1] 16:09:23.903 evsub.c ....Subscription Does Not Exist for SUBSCRIBE, event=message-summary;id=
[22.06.2021 16:09:24.556][1] 16:09:24.556 pjsua_core.c .Destroying...
[22.06.2021 16:09:24.556][1] 16:09:24.556 sip_transactio .Stopping transaction layer module
[22.06.2021 16:09:24.556][1] 16:09:24.556 sip_transactio .Stopped transaction layer module
[22.06.2021 16:09:24.556][1] 16:09:24.556 sip_endpoint.c .Module "mod-unsolicited-mwi" unregistered
[22.06.2021 16:09:24.556][1] 16:09:24.556 sip_endpoint.c .Module "mod-pjsua-options" unregistered
[22.06.2021 16:09:24.556][1] 16:09:24.556 sip_endpoint.c .Module "mod-pjsua-im" unregistered
[22.06.2021 16:09:24.556][1] 16:09:24.556 sip_endpoint.c .Module "mod-pjsua-pres" unregistered
[22.06.2021 16:09:24.556][1] 16:09:24.556 sip_endpoint.c .Module "mod-pjsua" unregistered
[22.06.2021 16:09:24.556][1] 16:09:24.556 sip_endpoint.c .Module "mod-stateful-util" unregistered
[22.06.2021 16:09:24.556][1] 16:09:24.556 sip_endpoint.c .Module "mod-refer" unregistered
[22.06.2021 16:09:24.556][1] 16:09:24.556 sip_endpoint.c .Module "mod-mwi" unregistered
[22.06.2021 16:09:24.556][1] 16:09:24.556 sip_endpoint.c .Module "mod-presence" unregistered
[22.06.2021 16:09:24.556][1] 16:09:24.556 sip_endpoint.c .Module "mod-evsub" unregistered
[22.06.2021 16:09:24.556][1] 16:09:24.556 sip_endpoint.c .Module "mod-invite" unregistered
[22.06.2021 16:09:24.556][1] 16:09:24.556 sip_endpoint.c .Module "mod-100rel" unregistered
[22.06.2021 16:09:24.556][1] 16:09:24.556 sip_endpoint.c .Module "mod-ua" unregistered
[22.06.2021 16:09:24.556][1] 16:09:24.556 sip_transactio .Transaction layer module destroyed
[22.06.2021 16:09:24.556][1] 16:09:24.556 sip_endpoint.c .Module "mod-tsx-layer" unregistered
[22.06.2021 16:09:24.556][1] 16:09:24.556 sip_endpoint.c .Module "mod-msg-print" unregistered
[22.06.2021 16:09:24.556][1] 16:09:24.556 sip_endpoint.c .Module "mod-pjsua-log" unregistered
[22.06.2021 16:09:24.557][1] 3CXTunnel: Bridge 1 destroyed
[22.06.2021 16:09:24.557][1] 3CXTunnel: Bridge 1 Stopping connection 13C40298
[22.06.2021 16:09:24.557][1] 3CXTunnel: Bridge 1 Destroying Demultiplexer
[22.06.2021 16:09:24.557][1] 3CXTunnel: Bridge 1 Closing TCP multiplexer loop
[22.06.2021 16:09:24.557][1] 3CXTunnel: Bridge 1 Multiplexer 138D5F08 destroyed
[22.06.2021 16:09:24.557][1] 3CXTunnel: Bridge 1 Connection 13C40298 destroyed
[22.06.2021 16:09:24.557][1] 3CXTunnel: RemoveBridge: bridge removed with ID 1
[22.06.2021 16:09:24.557][1] 3CXTunnel: RemoveBridge: ID 1
[22.06.2021 16:09:24.557][1] Tunnel transport 08FAB8F8 destroyed
[22.06.2021 16:09:24.558][1] 16:09:24.558 tcplis:52812 .SIP TCP listener destroyed
[22.06.2021 16:09:24.558][1] 16:09:24.558 tlslis:52813 .SIP TLS listener destroyed
[22.06.2021 16:09:24.558][1] 16:09:24.558 sip_endpoint.c .Endpoint 08F6F3CC destroyed
[22.06.2021 16:09:24.558][1] 16:09:24.558 pjsua_core.c .PJSUA state changed: CLOSING --> NULL
[22.06.2021 16:09:24.558][1] 16:09:24.558 pjsua_core.c .PJSUA destroyed...
[22.06.2021 16:09:24.558][1] 3CXTunnel: Stopping tunnel service, waiting indefinitely
[22.06.2021 16:09:24.558][1] 3CXTunnel: Tunnel service destroyed
[22.06.2021 16:09:24.558][1] Biz FreeSIPResources finished
[22.06.2021 16:09:24.589][1] Setting app channel to null, was [ 43680716 with https://REDACTED.tx.3cx.us:5001/myphone/MPWebService.asmx ]
[22.06.2021 16:09:24.589][1] UnsubscribeEventsFromMyPhoneAndCTI()
[22.06.2021 16:09:24.632][1] Setting tmp channel to null, was [ 43680716 with endpoint not selected yet from='https://REDACTED.tx.3cx.us:5001/myphone/MPWebService.asmx' ]
[22.06.2021 16:09:24.632][1] UnsubscribeEventsFromMyPhoneAndCTI() finished
[22.06.2021 16:09:24.632][1] Disposed myphone channel successfully during release and shut down
[22.06.2021 16:09:24.716][1] Line unregistered with code 0
[22.06.2021 16:09:24.720][1] channel_ServerEvent() channel mismatch: current tmp channel = null, app channel = null, got channel [ 43680716 with endpoint not selected yet from='https://REDACTED.tx.3cx.us:5001/myphone/MPWebService.asmx' ]
To first get a better idea of your setup, please provide the relevant information mentioned here:
https://www.3cx.com/community/threads/information-to-provide-when-requesting-help.67558/
Also, have you noticed if the 3CX Windows App crashes in specific situations? (e.g when receiving a call, when placing a call, when putting a call on hold, when launching another application etc)
As a quick test, please try the following:
1. Access the Management Console and go to Extensions.
2. Edit the Extension used by the affected 3CX Windows App and go to "Phone Provisioning"
3. Select "3CX App" from the "Your phones" drop-down list and scroll down to where you see the audio codecs.
4. If OPUS is one of the audio codecs, remove it completely from the list by hitting the X on the right hand side.
5. On the affected PC, completely exit the 3CX Windows App by going to Settings (cog wheel) >> Exit Client
6. Re-launch the app and check if the issue persists.
gmacinit
